TSP 231/237,.589"/.595" BUT on a 115LSA
What do you guys think about going with the same specs as the TSP 231/237 cam but in a 115LSA?? I am currently building a 8.5:1 383 for my ATI D1-SC and i was wonder would it work with a higher LSA so not to bleed of so much boost. I really dont want to spin over 6500 RPM so thats why i am thinking about a cam thats not as HUGE as most do with a 383. Thanks
Kyle
Kyle
Terry,
U think that it is to hi to shift at for a cam that big?? I have a 212/218 in there right now and it made power to 5800 and Jason at MTI put my shift point at 6100 rpm. I was told it is always better to go a couple hundred RPM's beyond a cams peak HP. Thanks
Kyle
Kyle
Originally Posted by Ragtop 99
Grind some advance in and it will probably work. The bigger cubes should eat up some of the extra duration.
Thanks, Kyle
kyle, z-rated is talking about intake center line not lobe center line. what he is saing is that go with the 115 LCA but install it at a 112 ICL which might work. the only way to know for sure if to change the ICL and dyno it every time until you get the best results. to get a good idea, as to were to start, i would call the comp cam help line and ask them what usually works for motors at those specs.
