How to rev higher?
How to rev higher?
I have some pretty newbie questions that were not answered clearly in the search or the stickies. Should be pretty easy for the resident experts.
What keeps an engine from revving higher? I know there are rev limiters (what are ours set for on a stock LS1?) that limit it, but what keeps it from physically or mechanically revving higher and is it always beneficial to get some more RPM's out of it?
Obviously torque will drop at a certain point, but our engines produce power beyond our rev limiter for durability sake (i'm assuming).
What factors have the biggest impact on our cars not revving higher and how can i get it to rev higher? I'm guessing valvetrain, engine internals, fuel system, and ignition all affect it, but are all those things as important as the next?
I'll be doing a cam swap in the next few months and was wondering if upgraded springs and pushrods and the little valvetrain accessories will allow the engine to rev higher than it does now.
What is everyone revving to on an auto with a stall converter in the 32-4400 range?
If you have taller gears (3.90-4.10) and you could rev higher, would it allow you to run that taller gear without running into OD easier (in the 1/4)?
Just trying to iron out my knowledge without guessing at things, thank you all.
Short answer here, on my way out to work..
You should be shifting around 6300 RPMs and limiter should be raised (by a tuner, handheld or dyno) to around 6600 RPMs.
Rod bolts are a very weak link and are reall strained in the higher RPMs, also stock push rods have a hard time in the higher RPMs.
Hope that helped, sorry so short.
Cam, Valve springs, and a good tune and you should be safe up to around 6800 some guys do push a little past that but i would strongly recomend rod bolts at that point.
reducing valvetrain weight while increasing the strength will let you rev higher. do a dual valvespring with titanium retainers, lightweight rockers, titanium valves, chromoly pushrods etc and you could rev into the low 7's if you wanted. (even though it may not be beneficial)
fwiw, for a mild h/c setup that I have, with 4.56 gears, 7100 rpm shifts gave me the best times. Higher stayed the same, and lower lost time.
FWIW on a stock cam you will gain NOTHING but extra wear and tear by spinning higher...
2nd on stock 99 rodbolts even after the other valvetrain upgrades I would not spin it over 6500. 01-02's can safely spin a little higher due to better RB's
3rd some on here will disagree on this but if you just drop the pan and install better rodbolts I would only use Katech's. They are the only aftermarket RB designed as a direct replacement. That is all I'll say as there is tons of info on this subject if you search on here......
You would need new lifters/rockers/PRs/cam then, and its not worth going solid roller for a street setup IMO. You can get astounding results with hyd setup with gen III engines.
True. Should only go double spring for high lift cams like 615+ lift.
I think ARP has some RBs that did past the test of abuse.
I was hoping that someone would be clear on the subject for the OP SOMbitch was; stock cam is good for the stock range it has. Just look at the LS6 cam in the Z06; it has more top end, but you need better springs already to support it plus its matched with the LS6 intake/heads, a lot better than the LS1 intake/heads.
The cam is the brain that will dictate at first were your powerband will be, after that, its all in the other parts around it; intake, heads, displacement, valvetrain,etc.
