Best Replacement Valve Springs for Stock LS6 ?
Seem to be a lot of scuttlebutt on LS6 valve spring failures on 2002 Z06 Corvettes.
What is the best replacement valve springs for a stock LS engine?
Seems double springs would be overkill for a stock set-up.
Again - this is a stock engine. I do not want to place place unecesary stress on the rest of the valve train.
I spent a lot of time searching - and found lots of good information. However - a lot of the folk seem to have cam modified engines which have diffent spring requirements.
Thanks !
- PAC 1218
- PAC1518
- Comp 918
- Other????
Thanks !
LS1Tech Premium Sponsor
Are you planning to keep the stock camshaft in place, or swapping down the road?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
