Another ticking ?
Old 11-08-2009, 09:13 AM
1 QUIK LS1's Avatar
Default Another ticking ?
A friend of mine has a 02 T/A stock motor bout 68,000 on it just your normal bolt on's. It started a loud ticking lastnight sounds like its at the pass. side front top of the motor. It only does it when you start to give it gas, at idle you don't here it at all. Not missing runs smooth and oil pressure is fine. I don't think its a header gasket either but going to tighten the bolts up to make sure. Thanks for any input on what it could be.......
Old 11-08-2009, 09:23 AM
Titanws6's Avatar
Possibly bent push rod
Old 11-08-2009, 06:06 PM
1 QUIK LS1's Avatar
Well tightened all the header bolts none were that loose,Pulled valve cover took all the rockers off........no bent push rods or anything wrong with the rockers. I guess its gonna be a lifter...........
Old 11-22-2009, 04:31 PM
ZeeTwentyFate's Avatar
mark did you guys check all the plugs? maybe one is loose
