Can you replace main bolts while the motors together?
Old 12-27-2009, 05:01 AM
99Ws6TransAm's Avatar
Default Can you replace main bolts while the motors together?
Im having to drop my oil pan outta my car here this spring. I have a tubular k-member and the trans will be out. I was thinking while i had it off to changed the main bolts. Is it as simple as just taking the bolts out and putting the studs in? Of course in order, with moly lube, ect ect.
Old 12-27-2009, 05:11 AM
bww3588's Avatar
simple answer...no.
when you change the main bolts to studs, it must be align honed. the clamping force changes and will "oval" the main bores. they need to be re trued.
so basically, if you want to put main studs in, the engine has to come totally apart.
Old 12-27-2009, 06:15 AM
...with cheese.
Armageddon's Avatar
Is it physically possible to do it? Yes
Is it a good idea? No.
Old 12-27-2009, 07:59 AM
G Engines's Avatar
What you can do is change to ARP bolts not studs the bolts don't distort the main bore, as where it was stated thee studs apply a much higher clamping force due to the fine thread.
Old 12-27-2009, 08:17 AM
crainholio's Avatar
It's difficult to find a good reason to do this. The kinds of power upgrades that would expose the mainbolts as a failure point are well beyond the limits of the cast pistons, so unless you're replacing them you aren't accomplishing anything useful by just replacing the main bolts.
Old 12-27-2009, 12:43 PM
KCS
Moderator
KCS's Avatar
+1
You would do more harm than good by going with studs. I wouldn't even switch to ARP bolts (if they even make them).
