first start after H/C install and no oil pressure...
Old 12-31-2009, 04:50 PM
LT1T/A's Avatar
Default first start after H/C install and no oil pressure...
After having the car apart for over 3 months, I finally cranked up the car (98 t/a) after installing a new cam, ported heads, new oil pump, etc and there was no leaks or anything but after waiting the 5 longest seconds of my life the oil pressure gauge was still at the bottom of the gauge. please help!
Old 12-31-2009, 05:03 PM
LT1T/A's Avatar
Idk if this means anything but after both cranking the engine with the fuel pump fuse/ignition fuse removed and with the fuse in place the gauge went up once the car was shut off/keys removed.
Also its about 10 degrees outside and everything sounds and looks fine otherwise.
Old 12-31-2009, 07:01 PM
Titanws6's Avatar
Have you tried it again? Has the gauge risen at all?
Old 12-31-2009, 07:09 PM
Josh18Fan's Avatar
Did you use a new pickup o-ring when you put it all back together?
Old 12-31-2009, 07:13 PM
SweeTbone's Avatar
Are you sure you didn't break your oil pressure sender right behind your intake manifold? Could have bumped it while reinstalling intake.
Old 12-31-2009, 09:46 PM
jomomma's Avatar
its sooo easy to incorrectly install the oil pickup oring! it happend to me a couple of months ago. it took me a while to accept the fact that i was going to have to pull the oil pan off again!
Old 12-31-2009, 10:56 PM
blu byu EH's Avatar
Its one of two things, oil pump o ring (not on right or its crushed) or the oil pressure sending unit.
Old 01-01-2010, 12:48 AM
eamador11's Avatar
I agree, do a search on technique to guarantee perfect install for o-ring
Old 01-01-2010, 10:56 AM
LT1T/A's Avatar
Im gonna take the intake back off and check the opsu and pray that I dont have to tear the front down again.
Old 01-01-2010, 11:07 AM
LS12Fast4U's Avatar
Good luck man. Hopefully it's just the oil pressure switch.
Old 02-21-2010, 08:03 PM
LT1T/A's Avatar
Update: So after taking off the oil filter and cranking the engine w/o the fuel, there was absolutely no change in oil drainage/dripage or spraying. I got to the oil pump and dissembled the pump. All the parts looked good despite not much noticeable porting work being done to it (it was a TSP ls6 ported pump).
This time I packed the pump with grease and reassembled it. The 0-ring I previously used didnt fit as snug as the new blue ring I got from GM. The old one was brown and thicker. The back of the pickup tube was covered in oil even with the pan being dropped a bit. Also, I blew compressed air into the tube to check for obstructions and the oil bubbled a lot.
Im going to fire it back up this week once I get some threaded rod to push the pulley back on. I hope all this was was the o-ring and/or lack of prime *fingers crossed*
Old 02-21-2010, 08:24 PM
SSdimension's Avatar
Let us know what happened. I had the same problem and never found the problem since motor blew a rod. Thanks.
Old 02-25-2010, 12:00 AM
LT1T/A's Avatar
Finished reassembling the engine tonight and it took about a good 7 sec of cranking the engine w/ the fuel fuse pulled to build pressure but boy did it build!
Upon start up it was about 70 psi and after letting it run for a few minutes it dropped to a sustainable 60 psi. Drove it 15 min home keeping the rpms bellow 2000 and it stayed at 60 during idle the whole time. Before I tore it down, the pressure was 40 psi during idle while hot.
Changed the oil when I got home and now I just have to save up a bit of $ to get it tuned by Straightline. Feels good
Old 02-25-2010, 12:14 AM
...with cheese.
Armageddon's Avatar
I've pulled down quite a few LS1s and I know exactly how you feel. The <10 seconds it takes to prime seems like a lifetime.
Old 02-25-2010, 05:04 AM
Congrats!!!
Old 02-25-2010, 06:54 AM
transam69230's Avatar
It will be pretty high like that for awhile until you get some miles on the car.
Old 02-25-2010, 09:26 AM
BES Stroked Nova's Avatar
yeah it take a little while for the pressure to build.....
Old 03-03-2010, 09:36 PM
SSilver Bullet's Avatar
Man I'm going through the same exact thing. I just finished the heads/cam an hour ago and my oil pressure is very low at idle, usually around 10 psi but has dropped as low as 6 psi. It builds pressure up to 40 psi when I rev the motor a little. Sounds like that o-ring, lot of work just for that little ring. BTW, I also purchased a TSP ported LS6 oil pump, and also installed that same blue o-ring you described.
Old 03-04-2010, 12:59 AM
froman's Avatar
just went through the same, here's a pic of my o ring.
Old 03-04-2010, 01:16 AM
LT1T/A's Avatar
It should be more like 40 psi @ idle. If its not the sender unit near the back of the intake like the guys mentioned in the post, then its probably your o-ring.
I gouged a chunk out of an o-ring trying to fit it in the first time too.
