lsr lobes?
lsr lobes?
okay I read a little bit about the new lsr lobes, they say there is 27 new grinds or something like that, what i was wonder is (maybe this should be in nubie tech because i feel like an idiot) im lookin at getting a custom grind around the high 22x and low 59x on a 112....does anyone know if i can get a custom grind with these lobes? and if so with these specs would this be a good idea?
Actually you are referring to the LSr family of camshafts using the LSL lobes. The smallest LSL lobe is 215* @ .050 and has .604" 1.7 rockers. These are very aggressive lobes but are also very stable. With a properly setup valvetrain and a high quality spring, they will make great power and RPM extremely well. Give me a call or PM me, I can suggest a few custom grinds that might suit your needs.
Thanks,
Shane
Thanks,
Shane
