383 with afr 225's hp?
Old 01-29-2010, 04:50 PM
butler's Avatar
Default 383 with afr 225's hp?
Putting the 383 back together, new bearings, but instead of the stock 853's going with the afr 225's, 72cc chambers roughly 10.5 comp. Motor is carbed(750 holley double pumper), vic jr intake, and an ms3 cam tight lobe separation. On the stock 853's it made 415 rwhp. What should I expect?
Old 01-29-2010, 06:56 PM
RENE'S RAGE's Avatar
I made 465/410 on my 382 with TEA TFS 215 heads.
Something to go by, maybe.
Old 01-29-2010, 07:32 PM
Flow Wizard
Tony Mamo @ AFR's Avatar
Why only 10.5 CR?
I would bump the compression and look for 40+ at the tire....maybe more.
You wont be disappointed Im sure
-Tony
Old 01-29-2010, 07:39 PM
hammertime's Avatar
415 is an excellent number with your drivetrain. My guess is that 225 and similar heads should be worth 40-50 hp at the flywheel. You might squeeze more out by bumping the compression up in the 11.2:1 range to work better with that cam.
That said, you're probably looking at 25-30 more hp at the tires...
Old 01-29-2010, 09:02 PM
butler's Avatar
Originally Posted by Tony Mamo @ AFR
Why only 10.5 CR?
-Tony
It's got arp studs and want to spray it with a 150 shot. Looking for 9's. 10.93 @ 124.5 best time with the 853's all motor.
Old 01-29-2010, 09:11 PM
AutomagicLS1's Avatar
