Head gasket question
i decided on leaving my ls6 heads alone until i build a motor for my car. I am planning on putting ls6 heads on my car within the next week or two. I was wondering what head gasket and what thickness i should use? I am fine with a bump in compression. The heads are stock casting 243's that have been cleaned and not milled. I have been looking at ws6store and texas speed and they have kits available for head swap gasket sets. Any ideas? Any input is appreciated.
If you're on a budget I would just go with the GM MLS gaskets. You can go ARP or GM bolts. I think either one will be fine. If you aren't hitting it with anything crazy as far as power adders go, I would just go GM. They will save you $90 and do the job for you. Let us know if we can help and we'll get you fixed up!
Jon
Jon
