LT1 - LS1 forged rods... fitment?
Hey guys getting ready to send a paypal but I want to double check with you all to clarify I'm getting the right connecting rods. Would be going into my 6.0 iron block w/ a 4.005 bore and 3.622 stroke.
Eagle H beams, were used in a LT1 hybrid type engine
6.125 length
2.100 journal diameter
0.927 pin size
6.125 length
0.927 pin size
LS1Tech Premium Sponsor
You need to make sure they don't have any offset like the typical SBC rod did. Most all of the LS1 specific pistons have the offset built in so you have to run a standard rod with no offset. Your journal and pins should be fine as long as your crank and pistons are the same.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
