Comp cam lifters
Comp cam lifters
What is the difference between the Comp Pro Magnum and the Comp High Energy Lifters? Theres only a $10 Dollar price difference.
D(irecto)r Pepper
Originally Posted by jrp
im using the 850-15 lifters with no problems. i asked about the compR lifters and the consensus was just stick with the gm oem ones.
DITTO, amigo. I have always just used the stock ones and have had excellent results.
Say your originals had 62K on them. If you were pulling the heads for a swap, what would you do then? I don't have any reason to believe that one is going bad or anything...I just figured with the heads off and that many miles, I'd replace them.
Does that change your mind, or would you just leave them be? New for new, the cost of the "R's" is waaay less than stock ones (as you already know).
