Pushrod Length
Old 03-05-2010, 08:18 PM
Ls1Mx-5's Avatar
Default Pushrod Length
I just ordered an Ms4 Cam kit from texas speed. I specifed that I wanted stock length "7.400"" pushrods. Texas speed just sent me an email
Originally Posted by Texas Speed
I also want to confirm which lifter set you are running. If you are running the factory LS1 lifters, you will need a 7.4250" length pushrod set. If you are running the GM LS7 lifter kit, you will need a 7.3750" length. Please let me know so I can make sure we send you the correct pushrod length for your setup.
Let me know how you would like to proceed, and I will take care of it for you.
Which set should I go with? 7.4250" or 7.400". Thanks guys
Old 03-06-2010, 02:01 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
go with what they recommend but I would measure too
Quick Reply: Pushrod Length
