Will stock rockers be OK with Ms4 and 243 heads
Sorry guys but i have to ask this. Im currently starting my H,C upgrade i went with ms4 cam new lifters (ls7) new push rods got a set of 243 heads and of course the double valve springs. My question is will stock rockers be fine my car has 140k on it but i would like to buy new stock rockers if they will work also post links where i could purchase stock rockers thanx for any advise sorry to bug you all with another rocker question.
http://cgi.ebay.com/ebaymotors/NEW-G...Q5fAccessories These are the same ones I am running. Have you done a compression test yet. Other than that if its a 00 or older and your going to spin that bad boy more than 6500 rpm I would also do rod bolts.
good luck
http://www.rockauto.com for stock rockers and yes you will be fine. i did the trunnion upgrade on mine that's just piece of mind for me. Also I would do the stock LS1/LS6 lifters and sell the LS7 lifters. A lot of complaints about lifter failure with them specially with aggressive cams w/ high lift #s.
good luck
good luck
good luck
good luck
i agree and you can get the turion upgrade from Thunder Racing as well..
