Reusing Bolts?
Reusing Bolts?
I have 2000 Trans am and i need to know what bolts are resuable and which ones i need to get. Because my motor is all stripped down to the core lol . so i need some help. Thanks
I have another question how do i determine or do yall know which diamond piston rings to get because that **** confuses the fk outta me and im not sure which ones i need because i dont wanna order the wrong ones .. thanks for the imput tho on the bolts
Senior Member
The TTY bolts are the heads and mains. Youll want to replace the heads bolts (I would get studs), mains, Rod bolts (known for many failures) and you can do the crank bolt too, but I dont justify the $25 vs $3 for a stock bolt.
