ls6 intake swap
Old 04-08-2010, 01:50 AM
nazztman4739's Avatar
Default ls6 intake swap
I am wondering if i was changing a ls1 intake to ls6 intake the tube that goes in the ls1 intake what do u do with it ?i figured block it off but will that throw a code?
Old 04-08-2010, 01:59 AM
LS1_Sean's Avatar
If you are talking about the egr tube, then yes you will need a block off plate. I may throw a SES code but can be tuned out.
Old 04-08-2010, 03:48 AM
bonethugluv's Avatar
if its for the 2001 ss in your sig, it should already have an ls6 intake on it.
Old 04-08-2010, 04:55 AM
LS1_Sean's Avatar
Old 04-08-2010, 06:01 AM
Predator's Avatar
Wasn't EGR removed for '01/'02 model years?
Old 04-09-2010, 01:06 PM
yeah im installing on a 2000 what else woul i need ?
Old 04-09-2010, 01:35 PM
Predator's Avatar
Remove the EGR tube and the EGR pump, then block the inlet into the manifold/header with a blockoff plate and a gasket. Finally just get the codes tuned out.
