flycutting new shortblock
Old 05-19-2010, 07:05 PM
massconfusion's Avatar
Default flycutting new shortblock
well i seized my motor on sunday and bought a shortblock for it on monday. The short block is almost brand new less than 500 miles and the bearings definately show that. It has new bearings, crank was polished, arp 2000 rod bolts and the mains are studded and this is all in 99 block. I had tsp 228r cam in my other motor so now i got to thinking why not fly cut the pistons and run the cam that i wanted to, an ms4. I couldnt run it before because i have patriot ls6 59cc heads. The only thing is i was planning on spraying my old motor and my understanding is i would be playing with fire if i sprayed on stock flycut pistons. Some guys do it sucessfully with small shots and good tuning while others melt through the pistons. Should i change my cam and fly cut or leave the short block as is and spray a decent sized shot through it. Oh and does anyone know where you can rent flycutting euipment, i know you can. 250 to have it fly cut seems a little expensive
Old 05-20-2010, 08:16 AM
i just reread the flycutting writeup. If anyone is rocking a setup like this or as an intelligent opinion i am open to advice
Old 05-22-2010, 09:11 PM
bump it
Old 05-22-2010, 09:58 PM
NHRAFORMULA00's Avatar
Send Chrs1313 a pm,he has flycutting tools he might rent out .He lives in Plainfield IL.
Old 05-23-2010, 01:11 AM
JFM-jr's Avatar
What size valves are you goin to be running?
Old 05-24-2010, 05:00 PM
i believe they are stock size, they are whatever size comes on patriot ls6 59cc heads
Old 05-24-2010, 07:58 PM
Paint_It_Black's Avatar
I just rented his this last weekend. I tried the sandpaper glued to the valves, but I wasn't happy with how that was turning out.. I think my cuts had to be too deep. The paper edges deteriorated by .085 and I needed to cut .110
Old 05-24-2010, 10:30 PM
chrs1313's Avatar
yeah flycutting is the way to go bump that compression and throw a .040 gasket on there and you car is really going to pick up...I have seen people cut as far as .120 and spray a 150 shot...
shoot me a pm if you want to rent the tools...
Chris
we need to cut some eyes in your cherry 15k miles factory stock pistons...
