oil restrictors?
Old 01-13-2004, 03:47 PM
2001CamaroGuy's Avatar
Default oil restrictors?
When running a solid roller valve train in "Old School" SBC and BBC, people would install oil restrictors into the oil passages at the rear of the block to prevent excess oil from going up into the head (which was no longer needed due to the hydraulic lifters no longer being in use) which would cut windage and keep the oil down in the bearings.
Is there such a setup for LS1s?
Old 01-13-2004, 03:50 PM
y2khawk's Avatar
nope
Gen 3's have a valve train priority oiling system, if you restrict the lifter galleys you cut oil flow to the bearings.
Old 01-13-2004, 03:55 PM
well that sucks.....oh well
Old 01-13-2004, 08:00 PM
LS1TECH Sponsor
Steve - Race Eng's Avatar
LS1Tech 20 Year Member
The only easy way to restrict the upper end oiling in the LS engines is by using solid rollers that restrict the oil flow to the pushrod or by using special pushrods with a small oil hole on one end. Either choice will help keep from pumping the oil pan dry on an extended high speed run.
Old 01-14-2004, 12:09 AM
y2khawk's Avatar
Folks have been bushing the lifter bores as well, with a much reduced oiling hole. Just another option.
