timing set??
Old 06-02-2010, 10:15 AM
skinumback's Avatar
Default timing set??
starting to piece together parts for my 6.0 build. what is the best performance timing set and oil pump to use?
Old 06-03-2010, 01:13 AM
jsafe's Avatar
for the price LS2 chain.. LS6 oil pump...
Old 06-03-2010, 01:22 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Unless for some reason you need an adjustable set. ^^^^^nails on.
Old 06-03-2010, 01:56 AM
brian_rs/ss's Avatar
yup yup. i have an ls2 single roller. i went with a melling pump. but i had a little money to blow so i said **** it...
Old 06-03-2010, 02:23 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Its barely a difference in price if you shop around for a melling or a blueprinted LS6. I think I found a melling for my old Z28 for about 16$ more than a LS6.
Old 06-03-2010, 02:31 AM
jugz ss's Avatar
I got the ls2 hd chain and gears and mellings high volume pump
Old 06-03-2010, 02:33 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That's the way to roll right there.
Old 06-03-2010, 02:34 AM
depending on the temp i can peg my oil pres guage with my melling. haha YAY OIL PRESSURE!
i'de say it's worth the extra little bit. but i may be biased.
Old 06-03-2010, 02:52 AM
jugz ss's Avatar
Yup Oil pressure sits at 60 when cold. 50 when warm and 50-60 driving at normal rpm.
Old 06-04-2010, 07:05 AM
99 Blue Bird's Avatar
question for those who may know. i just ordered a ls2 timing set for my motor but was wondering if there will b any excess slack in the chain cuz i had my block line honed to use ARP main studs?
Old 06-10-2010, 11:45 PM
printmanjackson's Avatar
every ls2 timing set I have seen had lots of slack.
