Compression Ratio Calculator ( Excel File )
Old 06-13-2010, 02:32 PM
Cold Zero's Avatar
Default Compression Ratio Calculator ( Excel File )
Hi guys
I'm searching about LS engine compression calculator that was made in excel file that include everything ( rod length , head combustion chamber , piston , gasket, ... Etc )
I had it in my previous lab top but I searched about it and cannot find it here
I found a thread with attach file but it doesn't work
Old 06-13-2010, 09:21 PM
G Engines's Avatar
This is the one i use from time to time
http://www.not2fast.com/turbo/compre...pression.shtml
Old 06-14-2010, 01:16 AM
00cls1camaross's Avatar
It is in the advanced section now.
I have it on my computer, PM your email and I will send it to you
Old 06-14-2010, 02:56 PM
hammertime's Avatar
Or, read the stickies at the top of this forum...
Updated Valve event / DCR / SCR / Header length spreadsheet
VE calculator.txt
Personally, I like this one...
My DCR Calculator - If you have a Comp grind, it doesn't get any easier than this...
But it looks like the links are broken (at least I can't load them here for some reason). I zipped my copy and uploaded it here...
Old 06-15-2010, 10:40 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Anybody know how to unlock that one with the Comp grinds??....I like using it but it annoys the fire out of me that compression is not spelled correctly on the dynamic line. Also I'd like to be able to add the newer Comp lobes to it. It's a handy calculator with a real easy to use interface!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Quick Reply: Compression Ratio Calculator ( Excel File )
