Who makes a 230/232 110 LSA cam?
I have a custom cam that came out of my 01 Z06... The previous owner said he bought it from vengeance racing. But this doesn't look like it's a cam they make. All the cam sheet says for place it was made is Custom Ground Camshafts Made in the USA.
The grind # is 230-232-10
Core:3310107
Camshaft Data=2
Duration At .05
Intake- Rocker Ratio= 1.7
Lash 23 24 25 Hyd
Exhaust- Rocker Ratio= 1.7
Lash 23 24 25 Hyd
Intake and Exhaust Lobe separation= 110 cam deg
valve overlap= 11 crank degree
intake
valve open= 7.3 BBDC
center line 107.9 ATDC
valve close= 43.4 ABDC
Duration 230.6 Crank Deg
lobe lift .35091 in.
valve lift .59654 in.
lobe area=28.23 in DEG
Exhaust
valve open=48.3 BBDC
Center line 111.9 BTDC
valve close= 3.8
Duration 232.1
lobe lift .34508 in.
valve lift .58663 in.
lobe area= 27.9 in deg
If anyone know that would be awesome...I want to sell this thing. But I would like to give someone the right info on this...just not say custom camshaft with these stats.
Thanks guys
Core:3310107
Camshaft Data=2
Duration At .05
Lash 23 24 25 Hyd
Lash 23 24 25 Hyd
intake
Exhaust
valve close= 3.8
Duration 232.1
Thanks guys
looks like a futral f13 on a 110 lsa...i should know cause i have one on a 112. mine measures out 230/232 .595/.585 112 lsa....i think thats very close to what you have
Cool thnx for the inputs guys. I had no idea where it came from since he didn't have anything put the print out of the specs. It was a pretty decent cam though. What would be a good asking price for it...It's got less than 1000 miles on it
