High oil pressure?
High oil pressure?
Ok so i have asked this before but all i get is a "Dont Worry", but i know there has to be something wrong. whenever i drive the oil pressure is at 75 psi and when im at an idle is is about 60 psi. there has to be something wrong cuz i recently started doing this.
ok so what about gas does it have anything to do with it. usually i put 91 from a shell gas station but today i went to costco and put 91 and my oil pressure went down to 40 at an idle. just wandering?
1 Post
no it is not the gas, check with a mechanical guage, seems your sending unit is crapping out, that what mine was doing. but if you have a HV oil pump then its normal. mine stays around 55 at idle
The following users liked this post:
Z45 (01-18-2024)
