Budget short block build/rebuild?
A "budget turbo build" has been snowballing and one upgrade leads to another, as always seems to be the case. My short block will probably have 80k on it by the time I install my turbo setup and retire it from daily driver duty.
I have a set of 317 heads I am going to put on, along with an LS6 cam and springs. Then I got to thinking about swapping out the rod bolts if I decide to drop the oil pan to tap for my turbo's oil lines, and I figured if the heads, intake, and cam were going to be off...as well as the oil pan and rod bolts...the majority of the engine's parts will be out of the engine bay.
Then I got to thinking, if I'm going to go that far, would it be easier to just build up a "budget" short block to replace the one in my car and just do an engine swap instead of taking it apart piece by piece while its in the engine bay? If I could do it for a reasonable amount of money, it might just be easier to do that. I can't really say what my "budget" would be for this "budget" short block build, it'll just come to a point where if it starts exceeding a certain price point I'd just say screw it and leave the stocker in there and run with it til it croaks. Being that I can buy a forged, bad *** short block from a builder for around $3k, I would put a "budget" build significantly less than that. Otherwise, what's the point? Might as well just get the forged one right?
What are my options for a "budget" short block build? Get a used LS1 short block, have it bored and oversized better pistons installed, new bearings, crank, etc? Find a 6.0L block at a junkyard and build up off that? I'm sure people build "upgraded" short blocks all the time this way, without going "all out" and doing forged, blue print/balance, etc.
This will be a weekend/fun car that sees the track once in awhile - not often though. I don't need or expect to make 900 horsepower, I'm just looking to make a safe and reliable amount of power for the max my turbo can support (MPT70...so 650/700ish flywheel?) and not having to worry if the next time I punch the throttle if my 80k+ mile short block is going to take a dump.
Am I asking to have my cake and eat it too?
For a turbo setup I'd a least do a decent h-beam rod and forged piston. Every engine built should be balanced so thats nothing crazy. You could always do a truck 5.3 oversized to a 5.7 then you have an iron block for some added strength. Clean up the stock heads and use dished pistons to take some compression out of it. That would be a somewhat cheap build that could hold a decent amount of power.
