wiseco piston?
Old 07-14-2010, 06:00 PM
dudeman's Avatar
Default wiseco piston?
i have a 6.0L wiht wiseco piston. i had a small problem and had to replace 1 piston. i called wiseco and told them i needed a right side piston. they sent a left. the valve reliefs are in the right spot, the dot is on the wrong side. is there a difference in the left and right pistons. could it have something to do with the pin. i wanted to put my motor back together tonight so i could have it runnign by saturday.
Old 07-14-2010, 06:38 PM
427's Avatar
The pin is offset, you need to wait for the right piston or it will be noisy.
Kurt
Old 07-14-2010, 06:55 PM
dudeman's Avatar
thanks for the info.
