Ls1 intalled rough accel in forward and reverse? low oil pressure?
Old 07-24-2010, 02:30 AM
504minivan's Avatar
Default Ls1 intalled rough accel in forward and reverse? low oil pressure?
OK did my ls1 swap now it idles great, but when i put it in gear and let off the brake it starts to kinda jump/ when accelerated it acts fine.
Also my oil pressure is jumping around 34-38 at idles.
Old 07-24-2010, 08:24 AM
nysbadmk8's Avatar
Oil pressure is Fine. If its jumping verify on a mechanical gauge.
Need more info on the motor and the application. Is it cammed? how is it tuned? etc etc..
Old 07-24-2010, 08:34 AM
504minivan's Avatar
ok this is a truck application, had a 5.3L in it with basic boltons and a 93octane tune fomr blacbear. 5.3l had 130k miles this motor is suppose to have 32k also it pings at 3krpms I am assuming this is a tune issue, maybe torque management?
It was a stock for stock swap.
Old 07-24-2010, 12:19 PM
gta3uzi's Avatar
Why would Torque Management make it ping? If it's motor knock that's going to be your tune tuned too hot or tuned incorrectly.
Old 07-26-2010, 06:57 AM
504minivan's Avatar
sorry lost my track of mind when i typed that, tune isn't my problem right now.
I have a far bigger problem, some way I am slinging oil under the whole truck assuming its the crank freeze plug or rear seal going to check further into it.
Dipstick & tube from 5.3 onto ls1 oil pan will not be accurate right?
Old 07-26-2010, 07:18 AM
bjamick's Avatar
No it will show way above full on the dipstick, bc the 5.3 pan is deeper than an ls1.
