replace oil pump?
Old 08-03-2010, 05:00 PM
Relic8723's Avatar
Default replace oil pump?
I just bough a LQ9 for my 3rd gen. I have the timing cover off and was wondering if i should replace the oil pump or just leave it. The motor has 145k miles on it. Also how much deflection should the timing chain have in it?Thanks
Old 08-03-2010, 05:13 PM
J1D2warrior's Avatar
if you have that many miles on it and easy access to do the job, then why not? invest in a chain and oil pump and gain piece of mind.
Old 08-03-2010, 05:44 PM
DCC!!'s Avatar
yes get one your already in ther and its worth the peice of mine you dont wana be back inside it and like 50 k or so
Old 08-03-2010, 05:56 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
i agree with these guys. 145k miles is quite a bit, for less then 200 bucks that it would be good piece of mind knowing you don't have to go back into it for a pump later on down the road.
Old 08-03-2010, 07:54 PM
DCC!!'s Avatar
^^^ they are where i got my pump and chain and a crap load of other stuff lol good guys!
Old 08-03-2010, 10:41 PM
Relic8723's Avatar
Default thanks
thank you for the info guys. thats exactly what i was thinking. Would gain definite peace of mind. Which timing chain set should I get for the LQ9 the ls1 or ls2 double roller set? Both are the same price i believe.
Old 08-04-2010, 01:21 AM
DCC!!'s Avatar
ls2 is a much better beefer chain ls1 guys upgrade to a ls2 chain so that should telll you alone
