how will a 234/232 590/590 114 cam run in a stock 6.0?
planing for my future 409 turbo set up and this was the cam Seth(cmotorsports) came up with. i wont have a 409 for awhile and i wont have a turbo for a month or so. wondering how that cam will run NA or with a little nitrous in an otherwise stock 6.0?
It will run fine. I am running a 235/239 .600/.590 on a 112 and it runs even without tunning. I've also run a TSP 231/237 and an F1 with no problems. Especially with the bigger bore motor you should be just fine.
Should be fine thats about the same lift as the cam that was in my 6.0, but mine was a 224/228. If I had know earlier I would have gone with more duration, like what you cam is.
