motor problem help.
motor problem help.
Im having problems with the car at the track,not pulling in third gear and miss firing.took it to the dyno,power is taking a dive around 5800,both with nos and na.motor 383,ls6 heads,comp cam,248/615 lift,114,patriot valve springs,fp was no lower than 58 psi,plugs looked good.dyno guy said it may be a broken valve spring,motor used to rev to 7000,with no problem.any ideas.
