Horsepower guessers come in!
Old 12-03-2010, 01:45 PM
driver56's Avatar
Default Horsepower guessers come in!
I'd like some opinions on potential power numbers, I know there's lots of variables but an estimated guess is better than no guess.
Here's the specs for a 402:
Approx. 11.8-12.0:1 compression.
Iron 6.0 block, standard bore.
4" stroke 4340 crank.
6.125 H-beam rods.
Flat top piston, 5cc reliefs.
Dart Pro-1 225cc intake runner heads, light clean up on intake side, light clean up with full polish on exhaust side, 2.05 intake valve, 1.60 exhaust, milled to 58cc combustion chamber.
Yella-Terra adjustable shaft rockers, 1.7 ratio.
Comp solid roller, 256in./262ex. @0.050, 0.690 lift both sides on a 106 LSA.
GM single plane with light clean up and a port match, HVH 2" billet tapered spacer on top to add some plenum volume.
850HP Holley, race gas.
Full MSD ignition.
That's pretty much the core parts, using the distributor conversion cover, going in a USMTS-type dirt modified. Like I said before, just rough guesses are OK. Thanks.
Old 12-04-2010, 09:16 AM
DaveX's Avatar
I don't know but with that setup you should consider a good port job on those heads. I think it would give you a significant increase.
Old 12-05-2010, 04:00 PM
driver56's Avatar
Awesome...... I guess nobody likes to play this game anymore.........
Old 12-05-2010, 04:39 PM
09camaro383's Avatar
Ill play I guess in the 515+ rwhp
Old 12-05-2010, 04:44 PM
djfury05's Avatar
maybe you should post it in the right forum then.. ill say 520
Old 12-05-2010, 05:04 PM
garygnu's Avatar
the heads need porting ,maybe 550.
Old 12-05-2010, 06:25 PM
mike c.'s Avatar
if you go to a dyno jet 525-535. a stang dyno less.
Old 12-05-2010, 07:39 PM
BIGSRTURBO's Avatar
Yea I was thinking 530ish on dynojet....
Old 12-05-2010, 11:18 PM
blue00ZZleeper's Avatar
I say 550-560 depending on tune...with race gas you'll be able to run more timing. I've seen quite a few high comp 402/408's make 530's pretty easily on pump. Thats a pretty stout combo you have. Should make for a mean all motor setup!
Old 12-06-2010, 01:36 AM
usafws6's Avatar
ill pull the high card 600rwhp. just because your using race gas, that makes for a very agressive tune possibility.
Old 12-06-2010, 03:50 PM
driver56's Avatar
All answers are very much appreciated. Thanks guys.
BTW.... I thought I was in the right forum??
Old 12-06-2010, 09:02 PM
ae13291's Avatar
depends on the tuner, your looking at 500ish should be a nice set up
Old 12-06-2010, 09:50 PM
djfury05's Avatar
There's a dyno and bench racing sub forum in the racers lounge that was made for this type of thing.. also the actual dyno forum.. just sayin you'd probably get more answers cause of the regulars who look for these threads
Old 12-07-2010, 10:01 AM
Always2Slow's Avatar
I'm just curious as to why your only running close to 12 to 1 on race gas? My estimate is 530
Old 12-07-2010, 12:13 PM
sscamaroburn02's Avatar
with race gas and that much compression I'd say around 550rwhp. That motor should run well
Old 12-07-2010, 01:08 PM
driver56's Avatar
We already had the flat top pistons for another project, we still might end up with a set of domes and bring the compression up some. I'd like to do 14-15:1 and put it on alcohol but the fuel system is already set up for gas.
How much would a Super Vic help on this engine?
