Linked lifters and trays
Old 12-15-2010, 10:21 PM
swift700's Avatar
Default Linked lifters and trays
Just wondering if I'd still use the plastic lifter trays for installing lifters that have the connector link between them. If I don't NEED to use the trays, could I use them anyways to make cam swaps easier?
Old 12-16-2010, 05:23 AM
S10xGN's Avatar
No, you cannot use the trays with linkbar lifters.
Old 12-16-2010, 07:42 AM
SS4Luck's Avatar
how would the trays make a cam change easier
Old 12-16-2010, 08:50 AM
Darkman's Avatar
I think that notion is based on the lifter trays holding the lifters in place during a cam swap.
After I had switched to link-bar lifters I came accross some magazine article that listed a disadvantage of switching to from lifter trays to link-bar lifters was that cam changes without pulling the heads were no longer possible. Since, I have not tried to change my cam again, I have not tested whether it is possible to to change the cam without pulling the heads once you have link-bar lifters, but I would sure like to know.
Old 12-16-2010, 05:12 PM
swift700's Avatar
Yes, this is what I meant. What are the advantages of the link bar lifters? Would they be ok for a DD?
Old 12-16-2010, 05:37 PM
Jon@Texas-Speed's Avatar
No sir, you can't use the trays with tie-bar lifters.
Jon
Old 12-16-2010, 07:23 PM
davidws6's Avatar
I remember reading a post where you can stuff an aluminum 3/8 rod ( Or Wood ) through the holes in the front of the block and gently go up under each lifter. Do a search and it will come up.
I have the link bars in my ls2 block and no problems with em.
I think they were Lunati part number 73432 or 72433
Quick Reply: Linked lifters and trays
