Possibly bent valves, now what
Old 12-23-2010, 05:33 PM
spdrcr7882's Avatar
Default Possibly bent valves, now what
When I reinstalled my crank and cam I intalled them out of sync, and I think I bent some valves. I my took my heads to a local machine shop, and he said it would be $160 for a valve job, (which I would have to reassemble them) and 350 total to have them cleaned up and reassembled. He also didn't think I bent any valves, just from looking at them. Does 350 seem like a resonable price to have the head taken apart, valve job done, and reassembled?
Thanks
Justin
Old 12-23-2010, 05:40 PM
garygnu's Avatar
if the heads are off face the intake ports up and fill them with solvent and mark the level of fluid.if the the fluid level goes down after a while you probably have a valve leak.do the same with the exhaust.
Old 12-23-2010, 09:09 PM
09camaro383's Avatar
I think 350 its a little too much here in Arizona the shops charge in the 240-275 to rebuilt your heads that includes cleaned up, valve job, new valve seals, resurfacing and reassemble
Old 12-24-2010, 12:59 PM
Lt1Porsche's Avatar
A shop I use regularly for head work full disassembles the heads, cleans everything up, check all tolerances, does a vlave job and reassembles for $120 a head. So 2 = $240.
Old 12-25-2010, 02:13 PM
spdrcr7882's Avatar
I took the springs off and the valves out already, so i can't check to see if they are leaking.
Im gonna call some shops and see what kinda prices other places have. I thought 350 seemed high
Justin
