copy cams on ebay
Camshafts can be reground there are businesses all over that specialize in just that. In fact most of your cam companies will regrind for you also call them and ask. We have had flat tappet cams reground for decades and actually get higher quality work then the cookie cutters. The OEM billet cams are heat treated through and hardened then tempered back to a specific hardness. Should be no issues. Some aftermarket billets are of lower quality materials than OEM and are case hardened. They are also case hardened for abusive load/ and more wear resistance such as solid rollers. You can run a regroud cam! I build Antique performance engines , there are only 2 choices new billet(custom made one off) or reground 95% are reground. These engines are up to 30K$ there are no shortcuts in a 30K$ engine and it has a reground, when there is nothing else available you rework/remanufacture the existing part to the specs. needed.
we see 2 major problems with these cams
1-the cam lobe isn't designed and or ground wrong, this leads to valvetrain instability and failure
2-the lobes aren't in the correct positions. While number 1 lobes might be close to where they belong in relation to the dowel pin, alot of the other lobes can be way off. This generally leads to poor performance due to each cylinder having different cam timing.
I got a regrind from Delta cams, They explained about the hardening process on the oem cams that it is hardened all the way through , they have been doing it for 40 years. $112.50 for a regrind. I figure why not. My car is not together yet, will be by spring, we will see.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Here's a good idea. Get a regrind from a trusted source. IE: NOT EBAY. I will pay for a new cam everytime, because that is what I have always done. Yeah, sure a regrind will work. Usually when someone has an engine failure and reveal the fact that they ran a reground cam, thats when its blamed for discussion sake. It could have been something else or just abused.
Just do your research. Many sponsors here offer packages that include everything you need for a cam swap. I would much rather spend with them because they keep this site funded. Without them, we wouldnt be here.
