A couple of LQ4 questions
Old 01-11-2011, 01:14 AM
1998LS1SS's Avatar
Default A couple of LQ4 questions
Fist of all, bad lifter killed my ls1. Now i dont know what rout to take. Lq4 or forged ls1.
I found a 05 lq4 with 35k. Guy at the junkyard turned the truck on, oil pressure was good with no noises- sounded really good. Engine will be a full longbock with manifolds and pcm. Price- $1300. Good price? I'll be throwing the eps 226/230 112lsa cam. Considering going with some 243 milled, if ptv will allow and if its within my budget. Im assuming transmission and accessories just swap over.
Or, i could purchase a forged ls1 shortblock with 6k miles for 1900 and throw some stock 241's on there.
Go ls1? Wait for a better deal on an lq4 or lq9? Let me know what you think guys.
For info-Car is full bolton, ls6 intake, pt4k stall.
Old 01-11-2011, 02:14 AM
King Nothing's Avatar
imo 1300 is a good price . . . why do you need to mill heads with that cam? i have the same cam sittin in my room but on a 116lsa and i don't need to mill them when i put it in (but i might cause mine will be for F/I), the engine it'll go in will have 243's also
Old 01-11-2011, 02:27 AM
1998LS1SS's Avatar
typo/grammar check- i mean to say that i will prob mill the heads to the point where i wont have any ptv issues. to gain some compression.
Old 01-11-2011, 03:01 AM
ah gotcha! either way it's a good deal IMO i picked up a longblock LS1 from a 00 z28 for $1400 with only 71K on it and so far this things runs like a champ. good luck with the route you go.
side note: we joined the same month of the same year and i have nearly 10x's the posts you have lol i'm a ***** i guess
Old 01-11-2011, 03:29 AM
1998LS1SS's Avatar
Lol thats true. I mostly just read around but when it comes down to dropping 2k sometimes i need a bit more reassurance.
Old 01-11-2011, 10:25 AM
very very true. when you get to droppin over 10k your post count will go up lol
Old 01-11-2011, 10:53 AM
99 Blue Bird's Avatar
i think i would take the forged ls1 if it was built by a good motor builder. than save for some heads to go with ur cam. were r u from?
Old 01-11-2011, 11:33 AM
it's the cali engine thread lol
Old 01-11-2011, 03:16 PM
1998LS1SS's Avatar
Baldwin Park. Ill try and drop the price on an the forged engine then maybe ill be able to pull the trigger
Dont know if I mentioned it but the lq4 comes with coil pacs and all accessories.
thanks for the input guys. keep it coming.
Old 01-11-2011, 03:29 PM
yea see if u could get the ls1 for like 1600 or 1650. if not then u could always get that lq4 and sell off all the stuff u dont need.
what exactly happened to ur motor?
Old 01-11-2011, 03:46 PM
ZexGX's Avatar
$1300 > $3000
For a good forged LS1 rebuild, it's gonna run you at least $2,200. Minimum. Assuming you assemble the shortblock yourself.
Old 01-11-2011, 05:55 PM
Also i forgot to ask but is the 05 lq4 a 58x tooth reluctor wheel?
Old 01-11-2011, 09:42 PM
1998LS1SS's Avatar
Failed lifter took out cam, timing chain, sprocket, couple of valves and who knows what else. Getting it checked this weekend. After i get a quote for the fix ill make my decision.
24 tooth. What I need.
Old 01-11-2011, 10:09 PM
NemeSS's Avatar
go with the lq4. mill the stock heads .030. get upgraded pushrods and springs. ls2 head gaskets. cam should work without ptv issues.
lq4 have 7cc spherical dish
but never hurt to check ptv clearance with any cam install.
317/243/799 heads share intake/exhaust runners cc and flow and valve sizes
chambers differ. 317 has bigger chamber
Old 01-11-2011, 10:56 PM
[QUOTE=1998LS1SS;14349553]Failed lifter took out cam, timing chain, sprocket, couple of valves and who knows what else. Getting it checked this weekend. After i get a quote for the fix ill make my decision
let me know if u go with the lq4. i would like to buy some of the stuff u may not need. pm me
Old 01-12-2011, 01:42 AM
1998LS1SS's Avatar
Thanks for the info. This will probably be the best bang for the buck.
Will do.
Old 01-17-2011, 12:46 AM
fastsspr's Avatar
with a 243 heads on a lq4 how much compression it going to have?
Old 01-17-2011, 08:05 PM
-Q-
-Q-'s Avatar
With a stock head gasket, I believe that it will be around 10.2:1. I know that with my 62cc PRC Stage 2.5 LS6 heads and a stock head gasket that it will be 10.55:1...
Old 01-18-2011, 12:22 AM
Slow5.0.'s Avatar
I ran over 700whp for 2 years with a untouched lq4.. food for though. Almost same set up you are looking at.
Old 01-18-2011, 08:36 PM
desertLS1's Avatar
My 18k mile LS6 blew up randomly on Saturday.
I ran into a good deal on a short block low mile LQ4.
Assuming my LS6 crank is not too hurt and reusable, should I swap that crank over? Or is the LQ4 crank good enough?
Sorry to hijack, I'm in the same position lol
