Cam Timing Marks?
Old 01-16-2011, 04:42 PM
Paul 75 L82's Avatar
Default Cam Timing Marks?
Sure looks like I got the marks alignment aligned OK, what do you guys think?
Old 01-16-2011, 05:01 PM
masterz28's Avatar
Yeah, looks good. I am used to the dots on the fbodies.
Old 01-16-2011, 05:13 PM
Thanks!
Old 02-21-2011, 11:43 PM
firechicken76's Avatar
What would happen if you rotated the crank a full rotation back to the dot? would it still be good?
Old 02-22-2011, 09:09 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
If you only go 360º on the crank, the cam gear dot will be at 12 o'clock
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-22-2011, 09:11 AM
bayer-z28's Avatar
UUugh... I gotta learn how to degree these darn things.. I looked into it, but it just seems like a lot of picky measuring. And a little more difficult with the heads on the car.
Quick Reply: Cam Timing Marks?
