Oil Pan questions
Oil Pan questions
So today i took my engine out to do some work on my K-member and do some other stuff. Well i found my oil leak. Coming from the Oil pan gasket. I got a new GM gasket. When i took off the oil pan this is what i found. A crack in a hole. This is right above the oil filter. Not sure what happened here. The engine came off a 2000 camaro. Not sure what the history is and there is also some rivets on the oil pan gasket. Do i need to drill them out and replace with some new rivets? One more thing, Is there a part# for the gasket right above the oil filter? Thanks
Joey J.
Rivets
Oil filter feed?
Above outside of oil filter
Joey J.
Rivets
Oil filter feed?
Sorry, not seeing your "crack". Buy a new gasket and use a torque wrench to install the pan. Yes, the small adapter has a gasket (don't have the part number), but make sure there's a plug in the fitting. I don't recall Camaro's having that particular fitting, only Corvettes with an oil temp sensor...
