do i need different pushrod length for cam change? what lenth is stock 6.0?
putting together a 6.0 with unmilled stock 317 heads, stock thickness headgasket, stock rocker arms and an untouched block deck. can i use the factory length and get some aftermarket ones at this length? im guessing i should be ok as nothing has deviated from factory spec only cam. if i can get away with a stock length then my next question is what is the stock length pushrod for a 6.0 lq9 motor? thanks guys for any insight.
