Help me pic heads!
Help me pic heads!
Ls1 block
Tuned for E85 fuel
853 heads (With recess) 10,1:1 comp and 2" intak valve or
862 heads 11,1:1 comp and 1,89" intake valve.
Truck intake, headers, no cats.
Is it possible to modify the valveseats for 2" valves on the 862 heads?
Thanks in advance
Tuned for E85 fuel
Thanks in advance
i'd opt to a set of 799 heads if its in the budget. But, given your choices i'd have the valve seats cut on the 862's to accept a 2" valve and take advantage of the higher compression. You could also have the 853's milled to bump compression but i dont think they flow as well as the 862's (i could be wrong).
Thanks for your reply!
I live in Norway and LS parts is hard to find..
But I have these heads, and the plan was to use the 853's but my MLS gaskets did not fit the recess heads..
Then I start looking on my 862's.
But can I mill the seats so 2" valves fit or must I replace the seats?
