head and cam trick flow
anyone use the trick flow head and cam packages. have good results with them. would recomend it. looking at the 515 hp package.. it that power acivable with the package. have an 01 trans am 6spd long tubes fast intake full exhust. just wondering what you guys thinks. i am seriously considering that package.thanks for the input.
515 is a flywheel rating. And yes Im sure it is attainable. The trick flow heads are good, really good. The cam? Well there are better choices out there most will tell you. Will that combo work as it is advertised? I would say yes.
We currently have our VRD/TFS heads & Cam package on sale for $2699.99
Package includes:
TFS 220cc As Cast Cylinder Heads
Fully Assembled including upgraded .650 lift dual springs
Mill cylinder heads to achieve desired compression
TrickFlow Hardened Pushrods
Camshaft of YOUR choice
Comp Trunion Kit for stock rockers
ARP Head Bolts
GM MLS HEad Gaskets
Front Cover Gasket
Front Cover Seal
GM Waterpump Gaskets
GM Crank Bolt
You can upgrade to Yella Terra Ulta Lite Roller Rockers for $249.00
Give me a call to discuss your specific goals. We will be happy to help anyway we can.
Package includes:
ARP Head Bolts
GM MLS HEad Gaskets
Front Cover Gasket
Front Cover Seal
GM Crank Bolt
would i have to degree the cam and check piston to valve cleance with the trick flow head package. also can i use ls7 lifters and ls2 lifter trays. on an ls1 is it realy hard to put the slp double roller and crank sprock on. heard you have to pull the crank sprocket off with a puller.is the crank knoched to line up the new sprocket. the 515 package would make 460 rwhp on a stick car what do you guys think thanks
