belt ronding
belt ronding
how do i run the belt and what size belt do i need for my 5.3l motor when i just want to run the water pump and alternator.no ac no powersteering do i need any adapter brackets or a alternator bracket do to it this way?
About the only way is to find someone with the same setup. If you cant do that, you need to not buy a bet at the moment and install everything the way it will be ran and then measure with a tape.
