what plugs should I be running?
Old 02-06-2011, 03:17 PM
98hc4mula's Avatar
Default what plugs should I be running?
Here is my setup
HKE 408/ AFR 205's,ARH 1 7/8 w/Catted Y,Fast 92&NWTB,K&N FIPK,HS Modified rockers,Pwerbond UDP. 11.2:1 CR tuned for the street on 93 octane.
circle D 4l80e and Circle D 3C converter.
konis,Adj PHB, 1Le Front S-Bar. MWFab9 3"short,Tunnel mount TA,MW LCA,Wavetrack w/4.10 gears,3.5"PST alum DS.
Billet Specialties 17x11 4.75 bs,17x7 fronts.
Best 11.2@120 1.56 60'
Im having a hell of a time tunning the cars Idle. It surges like crazy. I have tried everything I can think of with no luck.
I need to change the plugs bc its running too rich and I think they are fouled.
it was registering anywhere from 10-11.5 AFR
Old 02-06-2011, 05:55 PM
Cape T/A's Avatar
What are u running now? Dont really think your wheels are necessary to know when picking plugs, lol
Old 02-06-2011, 06:17 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Something a step or two colder than stock
Old 02-06-2011, 07:12 PM
jksellers87's Avatar
Default plugs
try e3 diamond fire plugs carb or injectors?
Old 02-06-2011, 08:00 PM
BriancWS6's Avatar
Ngk tr6
Old 02-06-2011, 08:06 PM
98hc4mula's Avatar
Lol. I copied my signature for the post. And didn't you know wheels are important for the car to run right haha
Old 02-06-2011, 08:07 PM
98hc4mula's Avatar
Ordered some tr6. That's what im running buy wanted to make sure they were right.
Old 02-07-2011, 08:29 AM
PREDATOR-Z's Avatar
Tuning should be your concern
Old 02-07-2011, 06:25 PM
98hc4mula's Avatar
the reason I asked about the plugs is bc I think the plugs are fouled. I have been trying to get the idle right but it is surging like its nobodies business.
Old 02-08-2011, 04:25 PM
PREDATOR-Z's Avatar
With HPT,
>Engine
>fuel control (This is the area you need to modify.)
>general Fuel (aftersart enrichement) {Take a look at the tables}
Also check Accel enrichement (not for idle though)
Old 02-09-2011, 02:36 PM
SVThuh's Avatar
NGK TR6 would be a great plug for your setup.
The next step colder plug is a BR7EF and it may be a bit too cold unless your going to be running n2o or boosting it.
What plugs are you running now?
Old 02-09-2011, 08:36 PM
trans_am7935's Avatar
so am i getting this right, heads and cam require colder then stock plugs?
Old 02-10-2011, 04:14 AM
PREDATOR-Z's Avatar
Not necessarily. Colder plugs will only compound the problem here if running rich. This is a tuning problem.
Old 02-10-2011, 04:28 PM
BriancWS6's Avatar
When you increase power as much as adding bolt-ons, heads, and cam does, it's time to go to a colder plug.
Old 02-12-2011, 07:31 PM
i am also getting the .040 MLS head gasket with 61cc chamber heads, i will be just over 11:1 compression, i was told with any more compression then stock, colder plugs is a must.
Old 02-13-2011, 02:33 AM
PREDATOR-Z's Avatar
Guys, there is a protocol to follow.
READ your plugs, if the flame burns too close to the tip, then yes you need 1 step colder, if the flame is firing correctly, it is not necessary.
That is how you determine if colder plugs are needed.
The cam plays a role (DCR).
Old 02-13-2011, 04:05 AM
thanks, so i will use my already installed plugs after my heads and cam swap, then check them in 10 miles or so and make a decision form there
