Heads and cam at 100k
Old 02-08-2011, 03:18 PM
Ws6R99's Avatar
Default Heads and cam at 100k
Hello ive been saving up for a few years now and just bought my self a 1999 ws6. I took it to the shop dropped it of and told them to freshen up the car. they replaced a few things nothing to big. The only problem is it has 112k miles on it. I was hoping to drop a Ms3 cam and a set of prc 5.3l heads on it. Has anyone else done this on a car with this many miles? whats everyones opnion?
Old 02-08-2011, 03:29 PM
ls1leadfoot's Avatar
i did it on my car at 92k and spun 2 rod bearings....thats just one outta a thousand chance though lol
but if that happens, you only have to build the bottom end as a result..lol
Old 02-08-2011, 03:30 PM
brians91formula's Avatar
I know plenty of people that have done heads / cam on a 100k+ car. You should be fine imo.
Does the motor have good oil pressure ?
Old 02-08-2011, 03:35 PM
Ws6R99's Avatar
Yes but i would replace the pump with a ported ls6 pump anyway its probably about time. Do you know any one running a ms3? im stuck between that and the 228r
Old 02-08-2011, 03:39 PM
pHEnomIC's Avatar
Rebuilding a bottom end is expensive. 1000-5000 depending on how you want to set it up.
Old 02-08-2011, 03:41 PM
Ws6R99's Avatar
Its cheaper to buy a new ls1 if im not mistaken. i just dont want to put 3 or 4k into the motor and have it fall apart
Old 02-08-2011, 03:44 PM
pHEnomIC's Avatar
But... back to your original question, i think you should be fine, if the motor blows up shortly after, it was probably gonna go soon anyways, provided you install things properly.
On the bright side, if you do invest in it, and something does go wrong, you can still reuse your parts in the new engine. Id say go for it.
Get the new oil pump, ls2 timing chain, etc and you'll be fine.
Old 02-08-2011, 03:46 PM
Ws6R99's Avatar
Thank you guys.
Old 02-08-2011, 03:50 PM
1972_Z-28's Avatar
Cool, about to do the same with mine at 109k, runs strong now but I've brought something else for a dd. So this is gonna be the nice day car hehehe
Old 02-08-2011, 04:03 PM
lemons12's Avatar
I installed ms4 at 99k along with 4400 converter.. at about 105 I did ported fast setup and 410s.. at about 110 I did prc ls6 heads.. sold it at 116k with around 25 track passes and hard street miles on it sill unning strong as ever. Was a 98 to boot.
Old 02-08-2011, 04:04 PM
lemons12's Avatar
on the other hand..92k miles spun a bearing with my 224 cam h/c/I setup. I think there was more to it than the motor giving though.
Old 02-08-2011, 04:07 PM
Ws6R99's Avatar
Any one have an opinion on if i should step up and go Ms3. or get the 228r
Old 02-08-2011, 04:10 PM
lemons12's Avatar
Lol.. if you are stuck between the ms3 and 228 you need to research more. One is a max effort cam, the other is a DD cam. You need to find out what you want, goals expectations etc, then research hard for a good two weeks.
Old 02-08-2011, 04:19 PM
Ws6R99's Avatar
yes im aware of that and i want all the power i can get. its not a daily driver and will hopefully see some track time. im just worried about the car holding up i dont want to stress it to much. but i think after this im going with the ms3
Old 02-08-2011, 08:45 PM
los p's Avatar
i installed a 228r cam at 129,000 and now has 140,000 still running strong with a lot of track passes and dd with a 150shot on top of that! so go ahead and pull the trigger bc these r some awsome motors!
Old 02-08-2011, 09:45 PM
99T/AMAN's Avatar
I put the el-torro cam in my car at 88k and also installed katech rod bolts. Cylinder walls still had the cross-hatches in them and the inside of the motor was very clean. Its all about how the car has been maintained and making sure you put the right parts on to hold up to what you want to do. Choosing the right set up is key also. My car beat a guy with a MS4 and more mods.
Old 02-08-2011, 10:01 PM
Restricted User
z99ls1's Avatar
If it were me I would not go with that big of a cam with those miles. Go with the 228r or something smaller than the ms3. Also are you manual or auto?
Old 02-09-2011, 06:17 AM
Captain Double Post
BOBS99SS's Avatar
Ms3 and a 228 are so far apart lol,I have a ms4 in my 99 and has 120k ,they way I see it when something goes its bound to happen,also with as cheap as the lq4s,lq9 blocks are going for if something fails at least you know there are great cheap options out there to upgrade to,this spring though I plan to check some things out just to make sure it will get threw the summer with out issues,sucks having the car down in nice weather,the ms3 is a good cam but its really what your goal is for the car,maybe look into the eps cams,Pat G knows his stuff,and they make some great power out of the smaller cams,big cams are good for the track but that's about it,
Old 02-09-2011, 06:38 AM
garygnu's Avatar
do a compression check and consider some new rod bolts(kaltechs).look at a torquer v2 or a 228r with 110 lsa.will need a good converter.
Old 02-09-2011, 07:53 AM
suvettetexas's Avatar
My 2- suggestions would be to do new oil pump and new rod bolts, either ARP or Katechs if you can afford them. I will be doing this soon to my 96k firehawk as well. Most of the problems you hear with people spinning rod bearings are due to stretched rod bolts and/or over revving the motor. Keep your shift points at a reasonable RPM and dont over do your rev limiter too much. I owned a 2006 TBSS with 85000 miles and prolly had over 300 passes at the track mostly on nitrous and following the tips described above never had an issue. These motors are pretty strong, but any insurance you can give them is just added security.
