regrind camshaft
Your engine can be changed from a reliable powerplant to scrap.
That's about it, unless you're paying to have the lobes re-hardened...in which case it's not much cheaper than just buying a new cam.
you serious? theres guys selling these left and rt on ebay,wonder if anyone left bad feedback cause of problems
ЯєŧąяĐ Єl¡m¡иąŧøя ™
They are reliable, but personally, I would get a new cam over one that has had a 2nd hardening process. They use the same cnc to regrind them with as they do a new cam from billet stock. If you can find someone that has had success with regrinds it might be worth saving 100$ over getting a new or used 1 time grind. I would definitely ask for a reciept as well as the cam card and appropriate engravings.
My 5.3 turbo motor has a ebay regrind in it. My buddies 6.0 turbo motor has the same ebay regrind in it. My buddies sprayed s10 with a Ls1 has the same Ebay regrind in it just on a different LSA. My buddies 98 H/C/I direct port nos system has a regrind with a lot of miles on it. No problems and all we do is beat on our stuff lol
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I have purchased three of them from ebay, and they are all JUNK! The first one was an ls6 copy, that isnt even close to the LS6 specs. The next one was ground wrong, and wouldnt run in hte car (had a miss) the third I wont use because the problems associated with the other two. Yes they will probably make the engine fire up, but the seller probably wont do anything about any problems, like in my case.
i have tried the ebay cams and the head studs, and have had terrible results with both of them. I will stay away from these at all costs.
