Slightly bent pushrod, and messed up a rocker.. HELP please!!
Just finished with my head/cam swap last week. Got the car running and it felt like it was missing. I just figured it was cause the cam was so big and I also swapped to solid motor mounts. Took the car for a dyno tune and the tuner felt the miss and did a compression test. My #6 had only 10#. So took the car back home(trailer both ways)and pulled my valve cover. The pushrod was wedged between the rocker and head. The pushrod has a VERY slight bent were it was wedged at. I'm not sure if I just put that rocker on wrong and did make sure it was seated properly or what. Now I'm not sure what to do or what went wrong. Here is a pic of the rocker.
Mods are: Polluter cam(242/244) Trick flow 220 as cast milled .010, 7.500 pushrods and yella terra 1.7's. PTV did not seem to be an issue but I did not check with a solid roller. I'm really bummed right now and will appreciate any help I can get.
What I THINK happened was I'm a moron and did not put the pushrod on the rocker all the way. When the cam came up it knocked the pushrod off and after letting the car idle it wedged the pushrod between the head and rocker arm keeping the valve open and bending the pushrod in the process. Does this sound feasible?
Yeah that silver mark is the paint rubbed off. It was not like that when I put it in. I am going to fill the cylinder up with air and see if it holds compression. If it does, I ordered 1 pushrod so I'll just put it in and give her a go. If it does not then the valve is bent and I'm fucked. From looking at the valve tips they are lined up and both look closed. We also didn't hear knocking when it was running. Although if there was slight PTV contact I doubt we could hear it. I appreciate the help.
I used the EO/IC method. I could of messed up but it is pretty simple. I got about 2 turns past zero lash so at worst my purhrods are .025" to long. Also my valve swipe is perfect without the yella terra shim.
Why are you measuring with stock rockers if you are using YT rockers? The shim will lengthen the pushrod requirement by around 0.075". If you followed LS1howto on the YT installation, the procedure isn't correct. Shim for wipe pattern, then measure for pushrod once wipe is correct.
I did follow LS1Howto for the YT install. It is actually the same instructions YT sent in the box. I did not install the shim and swipe pattern is good.
I installed the bent PR and re installed the rockers. Checked for compression and it was good. Started the car with valve cover off and it ran fine and the cylinder was firing. I think either I did not seat the PR on the rocker or is it possible the valve stuck? When we pulled the plug originally it looked like the cylinder never fired and all the others were rich.
