Finally about to order the parts for my motor.
Hello.
I am finally about to order the parts to build my lq4, I got moved into my new house. I got my garaged stocked with tools, and all the goodies.
I am just wanting to make sure I order the correct piston rings.
The block will be bone stock, machine work wise.
Will the 4th set of rings down on this link be the correct ones?
http://www.speedinc.com/cont.cfm?cid=C0001055
And any other info I might need would be appreciated. I am installing new cam, rod, and main bearings. Stock pistons, rods, and crank. New cam, springs, valve stem seals, retainers... Ls6 intake,
I am assuming I will be pushing around 500, maybe a little more. Do you all think the stock 26lb injectors will handle that hp, or should I get some 40lb injectors?
Thanks allot in advance.
Tyler
Tyler
Thank you.
In the last month and a half I have dropped about $6k in the project, another $3k and I will have all parts.
Below is what I got done in about 3hrs. I have 4 weeks of free time to finish this, took 5 weeks of school.
So lets hope I get here done.
