Torquing rockers to 30ft/lbs?
Kleeborp the Moderator™
Do you want to go through the trouble of drilling, tapping, and putting a threaded insert in the hole if/when you strip it out?
Steel screw + aluminum heads/threads doesn't leave much margin for over torquing, especially when the bolts are that small.
The torque wrenches I have that only go down to 30 ft-lbs are entirely too big to be used to torque the rocker arm bolts. Do yourself a favor and get the proper wrench, or borrow one from a buddy.
