need opinion on what cam to use
i have a 99 a4 camaro i have jba short headers slp mass air flow smooth bellow and slp inatke kit... flowmaster exhaust.. planning on installing a bbk manifold.... and either 410 gears or 373 what cam should i use i was thinkin about the trex magic stick is thewre any others out there?
If you are looking at those bigger cams, then you will need a converter. Also, it's hard for anyone to say what cam you should get just based on your current mods. What are your plans for the car? DD or track only car?
the biggest cam not make fastest car.you mite need a better flowing exhaust and a big stall for those cams.with out milling the heads and raising the static compression your dynamic compression will be low = a slow car.go to the TSP site and look at cams.its a small motor ,the more radical the cam the better the total combo needs to match.
