Cam question
Cam question
Well I have to ask, I've read everything till my eyes hurt and I'm still not sure so........... I have a 98 Z28 LS1 with a ton of miles and wanted to do a valve job some freshen up work instead.....I bought a set of 799 heads and am going to have someone install them along with a LS6 intake . I'm going to replace the lifters and push rods again because many miles on the car. I want to replace the cam at the same time but unsure of what to get. I am running stock manifolds and cats from an 2000 z28 and am going to keep this package. What would be a good cam to put in? I would like a little more power maybe another 60-70 hp. What are my options. This is my daily driver and i like the gas mileage.
Restricted User
You can't eat your cake and have it to. I would go with a low 220's cam since you have alot of miles. It won't drop your gas to much and it will still make somewhere around 40hp with just the cam.
Stock 241 heads, rockers, and F-body exhaust manifolds.
I was running Crane dual springs and they did very well since 2004, but the engine is getting a freshening from a suspected lifter failure so I'm going w/ PAC beehives this time around.
edit to add: the TR cam has very aggressive lobe rates and there's no way I'd run any factory spring w/ it. LS1 spring is out of the question regardless, LS6 spring might have enough coil clearance but the spring's rate is not likely to be stiff enough to keep the valvetrain under control.
I was going to use those yellow springs that come with the LS2 with 243 heads
holy mileage batman..buy some comp 918 springs.get a new oil pump and timing set,the thunder racing cam will work great.get some newer lower miles rocker arms .or do a comp cam trunnion upgrade.do a compression check and post your results.do a valve seat leak test on the 799 before you install them.if they weep do a valve job.
My Main concern is that with all the mileage on the bottom end, that is used to having the old parts, I don't want to double the pressure so to speak and blow out the bushings on my Crank. All being said, this is probably the best car I've ever had.
As for the rockers, even brand new GM rockers I've bought had a noticeable amount of play in the trunion shaft. Seems to be designed into them.
