What would be a better set up?
Just curious what would be better/make more power. A ls2 short block with milled 241 heads raptr cam and fast90/90. A ls2 short block with L92 topend and raptr cam. Or selling the ls2 short block for a good heads/cam combo for the 5.7 and keeping the fast 90/90. Also do u think someone would be interested in trading a 90/90 combo for the L92 topend.
LS1TECH & Trucks Sponsor
I think it depends a lot on what you want out of the car. The L92 top end will definitely give the most power, but it will be peak power. The L92 heads will cause you to lose some low end power, so if the car is more of a race car or weekend warrior that package might be the way to go. If you are looking for more low end power, or the car is a daily driver I would recommend the 241s or if possible some 243s. These heads will maintain compression and air flow so that you don't lose low end power.
