so confused about what valve springs i need.
its a 224/228 .566/.570 lift cam 114 + 2 LSA not sure who made the cam i just had the specs pulled off the end when i did the clutch. Based on the spec im going to use 1.8 rocker arms (.535/.538 with 1.7)spinning the motor 5,500 RPM max planned on sticking with single beehives, just not sure brand or pressures to use any idea?
vendors? and how is the price... like most im on a crappy budget ATM.. ive actually had very good luck with the Ls6 springs but going to a little more lift 1.7 vs 1.8 rockers i wanna find a semi cheap upgrade. Got the g/f the buy the rockers for doing plumbing @ here house looking to spend around 150-200 are 918s bad
Must be able to use stock keeps and retainers
so far ive looked at 1518,918, 1218, 26915,
gonna check out ps1 1511s and 1298s..
yes this is the DD no running it at the track..i do ilike to get some now and then though
LS1TECH & Trucks Sponsor
You could run either the PAC 1218 or 1518 depending on which you wanted. The PAC 1218 are rated to .600" lift and the 1518s are rated to .650". Since your cam is under .600" you could run the 1218s if you wanted, or the 1518s for some extra piece of mind. Both sets can be run with the stock hardware.
where can i buy the PSI @? is their a calculation i can use to determine the ammount of pressure i need ? duration in degrres vs the lift or something like that ??? wanna run closser the the minimum spring prssures i need
