View Poll Results: What size pr's did you use with your tsp cam with stock heads?
Stock Pushrods
0
0%
7.400 Pushrods
81.82%
7.425 Pushrods
18.18%
Other
0
0%
Voters: 11. You may not vote on this poll
What size pushrods did you use with your tsp cam with stock heads?
Old 06-28-2011, 11:39 AM
Restricted User
z99ls1's Avatar
Default What size pushrods did you use with your tsp cam with stock heads?
Thought it would be easier for people to decide what pushrods to order if we could see what most everyone is running with there tsp cam. Also if you want to say why you went with the pushrods you did that would help. So what pushrods did you use on your cam swap with stock heads/head gaskets?
z99ls1 is offline
Old 06-28-2011, 08:54 PM
farmington's Avatar
224r cam. stock heads, block, head gasket 99 z28. No valvetrain noise. great cam, by the way. 7.400 tsp pushrods
farmington is offline
Old 06-28-2011, 09:17 PM
Restricted User
z99ls1's Avatar
Awesome thanks man.
z99ls1 is offline
Old 06-28-2011, 09:35 PM
Gunrock_T/A_0811's Avatar
7.400 FTW, on a torquer V2 5.3 heads
Gunrock_T/A_0811 is offline
Old 06-29-2011, 01:14 AM
pyro719's Avatar
pyro719 is offline
Old 06-29-2011, 08:08 AM
RS_SS69's Avatar
7.375, 228r cam, stock 241 heads.
RS_SS69 is offline
Old 06-29-2011, 08:45 AM
thunderstruck507's Avatar
Comp Cams grind 230/224 reverse split, stock '99 heads surfaced my machine shop only, Felpro replacement thickness gaskets, GMPP lifters, 7.4 pr
thunderstruck507 is offline
Old 06-29-2011, 08:53 AM
1sicss's Avatar
Torquer 2, stock heads and gaskets, tsp 7.4 pushrods no noise.
1sicss is offline
Old 06-29-2011, 10:12 AM
jsteele90's Avatar
224/224 stock 243 heads and mls gaskets 7.400
jsteele90 is offline
Old 06-29-2011, 10:25 AM
bonethugluv's Avatar
7.400 pushrods is what i used too but i dont run that cam anymore with my new build
bonethugluv is offline
Old 06-29-2011, 10:50 AM
trey1010's Avatar
i used 7.4 pushrods with my 228r and the engine noise is quiet.
trey1010 is offline
Old 06-29-2011, 11:33 AM
Paul 75 L82's Avatar
I used the 7.4 pushrods with my 228R cam and it worked great. Here's the page from the service manual on rocker arm torque if you need it.
Paul 75 L82 is offline
Old 06-29-2011, 11:40 AM
Restricted User
z99ls1's Avatar
Thanks alot guys and everybody keep on posting what pr's you used. Thanks alot paul for the rocker arm torque document. I will be using that when I install my cam.
z99ls1 is offline
Old 06-29-2011, 11:46 AM
atrain59's Avatar
I used 7.4 pushrods with my 228R cam with stock heads and it's nice and quite.
atrain59 is offline
Old 06-29-2011, 02:01 PM
'02 WS6's Avatar
Ran 7.400 @ .100 preload on Torquer 2...still had sewing machine sound between .080 and .100 preload so just left it as is.
'02 WS6 is offline
Old 06-29-2011, 03:08 PM
PREDATOR-Z's Avatar
PREDATOR-Z is offline
Old 06-29-2011, 03:15 PM
NC98Z's Avatar
Originally Posted by PREDATOR-Z
Terrible isn't it? Place is full of them too!
NC98Z is offline
Old 06-29-2011, 06:53 PM
Restricted User
z99ls1's Avatar
Ok. Some explanation would be nice.
z99ls1 is offline
Old 06-29-2011, 09:44 PM
WS6tx's Avatar
Torquer v2 cam with comp 7.4 PR's no noise, stock size MLS head gasket.
WS6tx is offline
Old 06-29-2011, 10:25 PM
01ssreda4's Avatar
I know what you are doing here. You figure by using a poll it will help you with the pushrod length decision by giving you power by numbers (of responses that is). Some may agree that this poll of yours will work. I say ask TSP and/or measure for pushrod length yourself.
01ssreda4 is offline
Quick Reply: What size pushrods did you use with your tsp cam with stock heads?
