ls heads
Old 07-18-2011, 01:13 AM
95z286.0ls's Avatar
Default ls heads
can anyone tell me what the difference between 317 ls head and a 243 ls head .
thx joe
Old 07-18-2011, 02:44 AM
PREDATOR-Z's Avatar
317s are 6.0, 72cc heads, 2.00 intake 1.55 exhaust valves. Ver similar in design to the LS6 but with bigger chambers and a 4.0 bore chamber.
243s are 2 kinds, The light valved Z06 castings and the stainless valved ones, on LS2s, 5.3L etc motors. (similar castings are 799), 64.5cc, 2.00/1.55 valves.
Old 07-18-2011, 03:10 AM
95z286.0ls's Avatar
Default heads
so are the 317 a good set of heads do use im bilting a 395 cu in motor
Old 07-18-2011, 03:31 AM
hookngo's Avatar
some say 243 heads r better
Old 07-18-2011, 04:03 AM
PREDATOR-Z's Avatar
Ported yes, it really depends on the compression you wish to run. Both can reach over 300 cfms properly done.
Old 07-18-2011, 12:46 PM
95z286.0ls's Avatar
Default ls
ok if them heads will work will they work with the std bore 395 cu in or do i have to have a 4" bore to use these heads thx joe
Old 07-18-2011, 01:41 PM
PREDATOR-Z's Avatar
You can use them on 3.9x bore. 317s are used frequently on LS1/6 bores to lower compression for boost situations. Be aware if you use them you'll need 4.0 bore head gaskets
